Siglent Technologies SSA3075X Plus
The Siglent Technologies SSA3075X Plus device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SSA3075X Plus:
The frequency range of the Siglent Technologies SSA3075X Plus as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Siglent Technologies SSA3075X Plus.
Be careful changing these setting as RadiMation® is no longer able to verify if the Siglent Technologies SSA3075X Plus is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Siglent Technologies SSA3075X Plus
- Google image search: Siglent Technologies SSA3075X Plus
