Siglent Technologies SSG3032X
The Siglent Technologies SSG3032X device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Siglent Technologies SSG3032X:
The frequency range of the Siglent Technologies SSG3032X as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Siglent Technologies SSG3032X.
Be careful changing these setting as RadiMation® is no longer able to verify if the Siglent Technologies SSG3032X is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Siglent Technologies SSG3032X
- Google image search: Siglent Technologies SSG3032X
