Singer 94456-2
Jump to: navigation, search
The Singer 94456-2 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Singer 94456-2:
The frequency range of the Singer 94456-2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Singer 94456-2.
Be careful changing these setting as RadiMation® is no longer able to verify if the Singer 94456-2 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
