Solar 6338-5-PJ-50N
Jump to: navigation, search
The Solar 6338-5-PJ-50N device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Solar 6338-5-PJ-50N:
The frequency range of the Solar 6338-5-PJ-50N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Solar 6338-5-PJ-50N.
Be careful changing these setting as RadiMation® is no longer able to verify if the Solar 6338-5-PJ-50N is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
