Solar 6741
Jump to: navigation, search
The Solar 6741 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Solar 6741:
The frequency range of the Solar 6741 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Solar 6741.
Be careful changing these setting as RadiMation® is no longer able to verify if the Solar 6741 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
