Solar LISN
The Solar LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Solar LISN:
The frequency range of the Solar LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Solar LISN.
Be careful changing these setting as RadiMation® is no longer able to verify if the Solar LISN is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Solar LISN
- Google image search: Solar LISN
