Standard CDN Jig
Jump to: navigation, search
The Standard CDN Jig device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Standard CDN Jig:
The frequency range of the Standard CDN Jig as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Standard CDN Jig.
Be careful changing these setting as RadiMation® is no longer able to verify if the Standard CDN Jig is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
