Sunol Sciences JB3
Jump to: navigation, search
The Sunol Sciences JB3 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Sunol Sciences JB3:
The frequency range of the Sunol Sciences JB3 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Sunol Sciences JB3.
Be careful changing these setting as RadiMation® is no longer able to verify if the Sunol Sciences JB3 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
