TESEO LISN1-C
The TESEO LISN1-C device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEO LISN1-C:
The frequency range of the TESEO LISN1-C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TESEO LISN1-C.
Be careful changing these setting as RadiMation® is no longer able to verify if the TESEO LISN1-C is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: TESEO LISN1-C
- Google image search: TESEO LISN1-C
