TESEQ CDN M316
The TESEQ CDN M316 device driver is a Injection Device, LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ CDN M316:
The frequency range of the TESEQ CDN M316 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TESEQ CDN M316.
Be careful changing these setting as RadiMation® is no longer able to verify if the TESEQ CDN M316 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: TESEQ CDN M316
- Google image search: TESEQ CDN M316
