TESEQ CDN T2-10S
The TESEQ CDN T2-10S device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ CDN T2-10S:
The frequency range of the TESEQ CDN T2-10S as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TESEQ CDN T2-10S.
Be careful changing these setting as RadiMation® is no longer able to verify if the TESEQ CDN T2-10S is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: TESEQ CDN T2-10S
- Google image search: TESEQ CDN T2-10S
