TESEQ MD 4070A
Jump to: navigation, search
The TESEQ MD 4070A device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TESEQ MD 4070A:
The frequency range of the TESEQ MD 4070A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TESEQ MD 4070A.
Be careful changing these setting as RadiMation® is no longer able to verify if the TESEQ MD 4070A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
