TTI TGA 1241
Jump to: navigation, search
The TTI TGA 1241 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the TTI TGA 1241:
The frequency range of the TTI TGA 1241 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the TTI TGA 1241.
Be careful changing these setting as RadiMation® is no longer able to verify if the TTI TGA 1241 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
