Tegam 95241
Jump to: navigation, search
The Tegam 95241 device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tegam 95241:
The frequency range of the Tegam 95241 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tegam 95241.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tegam 95241 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
