Tekbox TBBCI1-CAL
The Tekbox TBBCI1-CAL device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tekbox TBBCI1-CAL:
The frequency range of the Tekbox TBBCI1-CAL as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tekbox TBBCI1-CAL.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tekbox TBBCI1-CAL is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Tekbox TBBCI1-CAL
- Google image search: Tekbox TBBCI1-CAL
