Tekbox TBCP1-500
Jump to: navigation, search
The Tekbox TBCP1-500 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tekbox TBCP1-500:
The frequency range of the Tekbox TBCP1-500 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tekbox TBCP1-500.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tekbox TBCP1-500 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
