Tekbox TBCP3-1000
The Tekbox TBCP3-1000 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tekbox TBCP3-1000:
The frequency range of the Tekbox TBCP3-1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tekbox TBCP3-1000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tekbox TBCP3-1000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Tekbox TBCP3-1000
- Google image search: Tekbox TBCP3-1000
