Tektronix AFG 3251
The Tektronix AFG 3251 device driver is a Signal Generator, Modulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix AFG 3251:
The frequency range of the Tektronix AFG 3251 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tektronix AFG 3251.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tektronix AFG 3251 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Tektronix AFG 3251
- Google image search: Tektronix AFG 3251
