Tektronix RSA5115
Jump to: navigation, search
The Tektronix RSA5115 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix RSA5115:
The frequency range of the Tektronix RSA5115 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tektronix RSA5115.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tektronix RSA5115 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
