Tektronix RSA6120
The Tektronix RSA6120 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Tektronix RSA6120:
The frequency range of the Tektronix RSA6120 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Tektronix RSA6120.
Be careful changing these setting as RadiMation® is no longer able to verify if the Tektronix RSA6120 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Tektronix RSA6120
- Google image search: Tektronix RSA6120
