Template:DeviceDriverInfo
Jump to: navigation, search
This template is used to show the details of a supported device driver. Possible named arguments are:
  • DeviceBrand: The brand of the device (also known as the manufacturer)
  • DeviceType: The type of the device (the type-number/description)
  • DLLFile: The name of the DLL in which the device driver is included, which can be a ;-seperated list of DLL files.
  • SupportedDeviceTypes: The numeric encoding of the supported device types
  • DeviceDriverName: The internal device driver name
  • HideAutoData: If the automatic 'guessed' data should be hidden (1: Hides the data)
  • GenericPage: The name of the page with some generic data of this device (which is used to group information of a serie of similar devices)
If an image of the device is also available, an image of the device will also be shown. The name of the images should match with (and case is important!):
  • Image:<DeviceBrand> <DeviceType>.jpg
  • Image:<DeviceBrand> <DeviceType> front.jpg
  • Image:<DeviceBrand> <DeviceType> back.jpg
If a page is present which is using less words, those pages will also automatically be linked.
An example of this template is:
Example:
The Rohde & Schwarz ESIB 7 Input 1 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DeviceDriverInfo:
The frequency range of the DeviceDriverInfo as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverInfo.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverInfo is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
