Teseo OTM301
Jump to: navigation, search
The Teseo OTM301 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseo OTM301:
The frequency range of the Teseo OTM301 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseo OTM301.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseo OTM301 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
