Teseq CBA 230M-035
The Teseq CBA 230M-035 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq CBA 230M-035:
The frequency range of the Teseq CBA 230M-035 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseq CBA 230M-035.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseq CBA 230M-035 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Teseq CBA 230M-035
- Google image search: Teseq CBA 230M-035
