Teseq GTEM-Cell 750
The Teseq GTEM-Cell 750 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq GTEM-Cell 750:
The frequency range of the Teseq GTEM-Cell 750 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseq GTEM-Cell 750.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseq GTEM-Cell 750 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Teseq GTEM-Cell 750
- Google image search: Teseq GTEM-Cell 750
