Teseq ISN T8
The Teseq ISN T8 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq ISN T8:
The frequency range of the Teseq ISN T8 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseq ISN T8.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseq ISN T8 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Teseq ISN T8
- Google image search: Teseq ISN T8
