Teseq NNB 41
The Teseq NNB 41 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq NNB 41:
The frequency range of the Teseq NNB 41 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseq NNB 41.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseq NNB 41 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Teseq NNB 41
- Google image search: Teseq NNB 41
