Teseq NSG 4060 Amplifier
The Teseq NSG 4060 Amplifier device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Teseq NSG 4060 Amplifier:
The frequency range of the Teseq NSG 4060 Amplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Teseq NSG 4060 Amplifier.
Be careful changing these setting as RadiMation® is no longer able to verify if the Teseq NSG 4060 Amplifier is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Teseq NSG 4060 Amplifier
- Google image search: Teseq NSG 4060 Amplifier
