Thurlby Thandar Instruments LISN 1600
The Thurlby Thandar Instruments LISN 1600 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Thurlby Thandar Instruments LISN 1600:
The frequency range of the Thurlby Thandar Instruments LISN 1600 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Thurlby Thandar Instruments LISN 1600.
Be careful changing these setting as RadiMation® is no longer able to verify if the Thurlby Thandar Instruments LISN 1600 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Thurlby Thandar Instruments LISN 1600
- Google image search: Thurlby Thandar Instruments LISN 1600
