Toellner TOE 7720
Jump to: navigation, search
The Toellner TOE 7720 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Toellner TOE 7720:
The frequency range of the Toellner TOE 7720 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Toellner TOE 7720.
Be careful changing these setting as RadiMation® is no longer able to verify if the Toellner TOE 7720 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
