Varian VZC6963 65
The Varian VZC6963 65 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZC6963 65:
The frequency range of the Varian VZC6963 65 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZC6963 65.
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZC6963 65 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Varian VZC6963 65
- Google image search: Varian VZC6963 65
