Varian VZL6943G5 (ELASIS)
Jump to: navigation, search
The Varian VZL6943G5 (ELASIS) device driver is a AmplifierCoupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZL6943G5 (ELASIS):
The frequency range of the Varian VZL6943G5 (ELASIS) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZL6943G5 (ELASIS).
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZL6943G5 (ELASIS) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
