Varian VZL 6941K7
Jump to: navigation, search
The Varian VZL 6941K7 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZL 6941K7:
The frequency range of the Varian VZL 6941K7 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZL 6941K7.
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZL 6941K7 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
