Varian VZM6993G6 (ELASIS)
Jump to: navigation, search
The Varian VZM6993G6 (ELASIS) device driver is a AmplifierCoupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZM6993G6 (ELASIS):
The frequency range of the Varian VZM6993G6 (ELASIS) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZM6993G6 (ELASIS).
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZM6993G6 (ELASIS) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
