Varian VZS6953G5
The Varian VZS6953G5 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZS6953G5:
The frequency range of the Varian VZS6953G5 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZS6953G5.
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZS6953G5 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Varian VZS6953G5
- Google image search: Varian VZS6953G5
