Varian VZX6983G5 (Alenia Range 10)
Jump to: navigation, search
The Varian VZX6983G5 (Alenia Range 10) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZX6983G5 (Alenia Range 10):
The frequency range of the Varian VZX6983G5 (Alenia Range 10) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Varian VZX6983G5 (Alenia Range 10).
Be careful changing these setting as RadiMation® is no longer able to verify if the Varian VZX6983G5 (Alenia Range 10) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
