Vectawave VBA1000-150
The Vectawave VBA1000-150 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Vectawave VBA1000-150:
The frequency range of the Vectawave VBA1000-150 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Vectawave VBA1000-150.
Be careful changing these setting as RadiMation® is no longer able to verify if the Vectawave VBA1000-150 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Vectawave VBA1000-150
- Google image search: Vectawave VBA1000-150
