Virtual Current Sensor
Jump to: navigation, search
The Virtual Current Sensor device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Current Sensor:
The frequency range of the Virtual Current Sensor as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Virtual Current Sensor.
Be careful changing these setting as RadiMation® is no longer able to verify if the Virtual Current Sensor is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
