Virtual Pre-Amplifier
Jump to: navigation, search
The Virtual Pre-Amplifier device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Pre-Amplifier:
The frequency range of the Virtual Pre-Amplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Virtual Pre-Amplifier.
Be careful changing these setting as RadiMation® is no longer able to verify if the Virtual Pre-Amplifier is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
