Virtual Pulse Limiter
Jump to: navigation, search
The Virtual Pulse Limiter device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Pulse Limiter:
The frequency range of the Virtual Pulse Limiter as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Virtual Pulse Limiter.
Be careful changing these setting as RadiMation® is no longer able to verify if the Virtual Pulse Limiter is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
