Wavetek 2520A
Jump to: navigation, search
The Wavetek 2520A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Wavetek 2520A:
The frequency range of the Wavetek 2520A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Wavetek 2520A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Wavetek 2520A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
