Werlatone Inc. C5827
The Werlatone Inc. C5827 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Werlatone Inc. C5827:
The frequency range of the Werlatone Inc. C5827 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Werlatone Inc. C5827.
Be careful changing these setting as RadiMation® is no longer able to verify if the Werlatone Inc. C5827 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Werlatone Inc. C5827
- Google image search: Werlatone Inc. C5827
