Agilent Technologies E7405A
The Agilent Technologies E7405A device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E7405A:
The frequency range of the Agilent Technologies E7405A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies E7405A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies E7405A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
