Agilent Technologies N9310A
The Agilent Technologies N9310A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies N9310A:
The frequency range of the Agilent Technologies N9310A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies N9310A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies N9310A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies N9310A
- Google image search: Agilent Technologies N9310A
The Agilent N9310A is a USB driven signal generator.
Manual[edit]
Programming manual can be found here
Quike start + short programming manual can be found here
Remote display on screen[edit]
When controlled by software the device will display the following image:
We have received the following information from Agilent regarding this item
I confirm you that under remote control, it is normal that the display of your generator is not updated, please refer to FAQ: http://www.home.agilent.com/agilent/faqDetail.jspx?cc=US&lc=eng&ckey=1110361&nid=-536902260.536908604&id=1110361 Regarding USB control, it is normal that even when closing your VISA session the instrument stands under remote control, as last software layer "USB Test & Measurement Instrument" is still active, but you can take instrument control back by simply using Local key on the front panel of the N9310A.
The text on the web page:
The N9310A screen is not updated when the N9310A is running a program. When doing the same operation in LOCAL mode, the display is updated. Is there something wrong with my N9310A?
Running your N9310A in remote mode brings forward the following two symbols:
- A red LED indicator is lit once the instrument is in remote
- A static bit map is displayed on the instrument’s screen, a refreshed screen is not available unless LOCAL mode is enabled.
