Agilent Technologies U2021XA
The Agilent Technologies U2021XA device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies U2021XA:
The frequency range of the Agilent Technologies U2021XA as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies U2021XA.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies U2021XA is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
