Anritsu MS2760A-0032
The Anritsu MS2760A-0032 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Anritsu MS2760A-0032:
The frequency range of the Anritsu MS2760A-0032 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Anritsu MS2760A-0032.
Be careful changing these settings as RadiMation® is no longer able to verify if the Anritsu MS2760A-0032 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
