Bird 4421 (Reflected)
The Bird 4421 (Reflected) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Bird 4421 (Reflected):
The frequency range of the Bird 4421 (Reflected) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Bird 4421 (Reflected).
Be careful changing these settings as RadiMation® is no longer able to verify if the Bird 4421 (Reflected) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
