Boonton 4220A
The Boonton 4220A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Boonton 4220A:
The frequency range of the Boonton 4220A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Boonton 4220A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Boonton 4220A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Instructions for configuring the end-of-string terminator[edit]
The device allows to set the end-of-string terminator configuration using the special function #02: "End-of-string selection". for more information please see the manual of your device (chapter 3-16 Special functions).
Instruction are provided below:
- Access the special function #02: "End-of-string selection" setting of the device, see the manual of you device regarding how to access the "End-of-string selection" settings.
- Use the end-of-string selection settings of the device to configure the end-of-string terminators.
- Set the end-of-string selection mode to the option shown as
L-CLon the display of the device(chapter 3-16 Special functions).- This sets the line-feed as terminator in listening mode.
- This sets the carriage-return + line-feed as terminator in talking mode.
- Press the "enter" key on the device to store the settings in memory on the device
