Boonton 9200A Channel 1
The Boonton 9200A Channel 1 device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Boonton 9200A Channel 1:
The frequency range of the Boonton 9200A Channel 1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Boonton 9200A Channel 1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Boonton 9200A Channel 1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
