Communication Streams
Device Driver
Reset
Text field to specify the reset command. The command is sent to the device during the test initialization.
Init
Text field to specify the initialize command. The command is sent to the device during the test initialization.
Get ID
Text field to specify the *IDN? query. The command is sent to the device during the device check.
Returned ID
Text field to specify the expected respond to have the Get ID compared with. The string is used during the device check in case a query is specified.
Deinit
Text field to specify the deinitialize command. The command is sent to the device during the test deinitialization.
Operation Complete
Wait for Operation Completion after sending command(s)
This will append the *OPC? to the commands being sent.
Test
Test started
Test stopped
Signal
Frequency changed
Keyword __freq__ will be replaced by the frequency in MHz.
Carrier Level changed
Keyword __carrier__, will be replaced by the carrier level in dBm.
Dwell-time
Dwell-time started
Dwell-time stopped
Modulation
Modulation on
Modulation off
Measurements
Before Forward Power
After Forward Power
Keyword __result__ will be replaced by measured Forward power in dBm.
Before Reflected Power
After Reflected Power
Keyword __result__ will be replaced by measured Reflected power in dBm.
Net Forward Power
Keyword __result__ will be replaced by measured Net power in dBm
Field Sensor
Keyword __result__ will be replaced by measured Field strength in V/m
Antenna Tower
Antenna Tower started
Antenna Tower stopped
Antenna Tower changed
Antenna Tower polarization
Turntable
Turntable started
Turntable stopped
Turntable changed
| keyword |
inserted value
| __freq__ |
the signal generator frequency expressed in MHz
| __freqHz__ |
the signal generator frequency expressed in Hz
| __freqkHz__ |
the signal generator frequency expressed in kHz
| __freqMHz__ |
| __freqGHz__ |
the signal generator frequency expressed in GHz
| __carrier__ |
the signal generator carrier level expressed in dBm
| __carrierdBm__ |
| __carrierW__ |
the signal generator carrier level expressed in Watt
| __carriermW__ |
the signal generator carrier level expressed in milli-Watt
| __forward__ |
the forward power expressed in dBm
| __forwarddBm__ |
| __forwardW__ |
the forward power expressed in Watt
| __forwardmW__ |
the forward power expressed in milli-Watt
| __reflected__ |
the reflected power expressed in dBm
| __reflecteddBm__ |
| __reflectedW__ |
the reflected power expressed in Watt
| __reflectedmW__ |
the reflected power expressed in milli-Watt
| __height__ |
the height where the antenna is moving to expressed in metre
| __heightm__ |
| __heightcm__ |
the height where the antenna is moving to expressed in centimetre
| __angle__ |
the angle where the turntable is turning to expressed in degrees
| __degree__ |
| __radian__ |
the angle where the turntable is turning to expressed in radians
