DARE!! Instruments RPR2018P
The DARE!! Instruments RPR2018P device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RPR2018P:
The frequency range of the DARE!! Instruments RPR2018P as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DARE!! Instruments RPR2018P.
Be careful changing these setting as RadiMation® is no longer able to verify if the DARE!! Instruments RPR2018P is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Value | Allows to select the filter that should be used in the measurement device. The possible filters are described in the manual of the DARE!! Instruments RPR2018P. |
There are several methods in which the DARE!! Instruments RPR2018P can be connected to the PC. The DARE!! Instruments RPR2018P can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the DARE!! Instruments RPR2018P is connected.
When the DARE!! Instruments RPR2018P is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
Directly to PC | Specifies that the DARE!! Instruments RPR2018P is connected directly to the PC, without the use of a RadiCentre. |
RadiCentre 1 | Specifies that the DARE!! Instruments RPR2018P is connected to a plugincard that is fitted in a RadiCentre 1. |
RadiCentre Multi-slot | Specifies that the DARE!! Instruments RPR2018P is connected to a plugincard that is fitted in a multi-slot RadiCentre. |
Device ID | Specifies the slot in the multi-slot RadiCentre in which the plugincard of the DARE!! Instruments RPR2018P is fitted. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the DARE!! Instruments RPR2018P itself. If RadiCentre 1 or RadiCentre Multi-slot is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a Multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the DARE!! Instruments RPR2018P is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the DARE!! Instruments RPR2018P:
- RadiCentre tab
- Connection type: RadiCentre Multi-slot
- Device ID: 3
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Software update tab can be used to update the firmware of the DARE!! Instruments RPR2018P.
Firmware | Specifies the filename of the firmware update file that should be used to update the firmware of the measurement device. |
Browse | Allows to select the firmware update file. |
Update Firmware | Starts the actual firmware update. First some checks are performed, and if those checks are successful, the actual firmware update is performed. |
Status | Shows a message during the firmware update, indicating the performed action and the actual status. |
